Hi, just picked up my 2007 bailey pageant Bretagne, dispatch team tel me 62 psi yet on label on van says 42 psi ???
(alloy wheels)
(alloy wheels)
62 sounds like the pressure for maximum tyre load, usually significantly beyond the MTPLM - but some manufacturers can't be bothered to do simple arithmetic and work out the correct pressure for the actual MTPLM.Damian-Moderator said:Is it a single or twin axle van?
If single, 62 is right, if twin 42 is right
RogerL said:62 sounds like the pressure for maximum tyre load, usually significantly beyond the MTPLM - but some manufacturers can't be bothered to do simple arithmetic and work out the correct pressure for the actual MTPLM.Damian-Moderator said:Is it a single or twin axle van?
gary said:42psi is the maximum pressure of a 'reinforced' tyre, 65psi is maximum for a Commercial van tyre, AKA 8ply tyre. So this looks like a confusion between two possible types of tyres fitted?
So simple enough, what is the size and load index of the tyre and the MTPLM of the van?
Looking at my tyres they are triangle gls tr 928, 195,70,r14, 95h Caravan Mtplm 1420, Miro 1195,
Done some research on triangle and reviews pretty good they supply caterpillar etc, however what I understand is that this is a car tyre and not suitable for light vans, as there is no such thing as a caravan tyre, a commercial van tyre is used I'm a little worried !!!!! Forgot !!! It's a single axle
