Unable to reply to topics or input text to body of "topic" which is why its blank below and this is a long subject header
2,400
I added the word 'Test' to your post so the comments box appears to be working Derek.
I'll contact you via email to find out the details and pass the info to the webtechs.
Jan 8, 2008
129
Do you happen to be using iPhone/iPod Touch/iPad?
EDIT - of course, if you are, you won't be able to reply, will you (slaps forehead).
If you're using one of the above, the rich text editor doesn't work. However, below it there's a link saying 'Disable rich-text' - if you click on that it turns off the rich text editor (funnily enough) and you can then use it. You're stuck without bold and italics and useful linking tools, but you can still enter those links using html if you know what youre doing*
*if you don't, I might do a 'plain text html linking and image inserting and stuff like that' primer...
Jan 10, 2010
168
Disabled rich text and as you can see it works, running windows 7 BUT recently downloaded IE9 beta, I wonder if that was the problem , word, outlook etc all still work,
just made a quick check seems to be a common problem you have to run ie9 in compatability mode to use rich text
