Dec 9, 2007
383
Hi Jim.
Your vin number should be etched into the bottom righthand corner of each window.
It should also be on the rectangular aluminium plate which bears the MIRO and MTPLM info.
Failing that, you should find it on the top surface of the chassis 'A' frame, under the fibreglass/plastic 'A'frame cover. It should be stamped into the galvanised steel chassis.
Hope this helps
Dave
May 30, 2008
Hi Jim.
Hope this helps
Dave
Thanks Dave&Dee, I'll check that 1st thing in the morning
