- Mar 14, 2005
- 19,227
- 4,398
- 50,935
I have to disagree about it being a "myth". If my VAG DPF light comes on, My own car's handbook tells me to drive at between 2000 and 2250rpm in 4th or 5th gear until the light extinguishes. On a couple of occasions the DPF warning hasn't extinguished, it goes into limp home and tells me to take the car to the garage. Having been stung once by the charges to plug in and ODB 2 Reader to set up the full regeneration and carry it out, I bought a second hand Delphi system and can now do it myself. - it's paid for its self.DPF regeneration doesn't need 2,000 rpm, that is an urban myth - on holiday I often cruise at 50 solo on ordinary single carriageway roads, about 1,250 rpm in top gear, but it'll carry out an active regeneration if it needs to.
My BiL owns a service garage and he tells me VAG's regeneration calls for teh engine to be run at about 2000rpm in 4th or 5th which agrees with the Delphi instructions.
The regeneration process attempts to get the DPF elements up to about +800C. It does this by using extra fuels to heat up the exhaust temperatures. There is a danger of exterior surface of the DPF getting too hot if the car is stationary, and it could start a fire on the car or damage the surface of the road.
My Delphi system can show DPF temperatures, and its quite sensitive to speed and gear ratios. Running at anything below 1900rpm it simply does not get hot enough.
It may be different for other manufacturers or models, but I can only relate my own experience, but this proves its not a "myth"
