Hi,can anyone tell me where i can buy a connector to allow the two waste pipes to go into one hose.
Ive tried all the usual shops but no joy
Thanks Trev
Thanks Trev
Sounds totally double dutch to me .Hi Trev
I use 32mm polypipe sink waste fittings, one t peice wp21, wp23 bend, & a wp15 bend, two 6in & 1 12in peices of pipe, wp23 pushes into the tee, 2x 6in into the van fitting tee & bend pushes on these 12in pipe into tee wp15 bendon pipe into waste container, nice & solid can also be extented if on sites with drains for each pitch, with 32mm pipe & sockets wp26 to any length I keep 3x1 mt long peices with sockets in van locker
mick k
my caravan has three waste water outlets shower, washbasin and kitchen sink i intend to join all together am a retired plumber so no problem will use a non return valve to stop backflow into showertray my question is where best to locate final exit to make use of a super pitch never used this type of pitch before and never taken any notice of the layout thanks harryI always have my drain pipe two into one via adaptor positioned just above the connection at the shallow end of my wastemaster, (like you do at home with your waste pipes from your house above the drain,) never ever had any problems with syphoning back.
