Waste Outlet - Help Please
Jan 10, 2009
6
Can anyone give me an answer to a question which, on the face of it, appears to be obvious as an obvious thing.
The waste outlet (1999 Lunar LX200)? What size of pipe? I've tried measuring and the internal diameter is about 23mm, the outer diameter 25mm. It really isn't that east measuring in 'millis' with a ruler. Do I need 23.5mm waste pipe or 1"?? Help please.
Mar 8, 2007
395
6
18,685
Paul,
You will need a lenght of corrugated Waste Pipe with a 1" bore Diameter, as the pipe will need to fit over the existing outlet.
The lenght required will depend on the location of your wastemaster/wasthog and if you need to connect the Kitchen Sink,Shower and Hand Basin as well, then just cut lenght to suit as this is normally sold by the metre
best regards, Martin
Feb 20, 2009
31
Hiya Paul, 25mm is 1 inch.your local caravan shop should have miles of it in stock and they should be more than happy to help.Its cheap any way..... Tip Before you leave the site to come home pour a kettle of boiling water down the plug hole and it clear's all the grease deposits in the pipe that builds up of dishes etc.... Good luck mate.
