Hi all,
Looking for some advice if anyone can help. I have a Senator with on board water pump and am experiencing a problem with the external water connection from the aquaroll to the van. It's the type with the filter that drops inside the aquaroll with a piece of hose leading to a square shaped fitting that plugs into the outside of the van. Once plugged in you close the flap over and that holds the water fitting firmly in place. I find it plugs in easy enough but is very difficult to remove. It is quite hard to get a firm grip of it and I find the only way I can remove it is to pull square fitting with one hand and the hose with the other. I am sure that one day I am going to end up pulling the hose off altogether. I have tried smearing the rubber "O" ring with vegetable oil prior to connection but makes no difference.
Anyone else experience the same problem or any ideas.
As I was writing this I was wondering if I switched off the water pump at main switch and opened a tap would that perhaps release the pressure and suction in the system and make removal easier?
Robert
Robert
