Water filter
Jul 28, 2013
91
Hi, I have a 2001 sterling Eccles sapphire with a whale water pump, my question is where would I find the filter my local dealer said it might be in the van itself but then again may not even have one as not all vans are fitted with one, personally I would rather have one any idea where It could be, or could I fit one myself if so what and where would I fit it, thanks.
40
If you look inside the caravan at the side where the pump connection is situated on the outside you will see the incoming water pipe - probably blue or clear with blue markings. Follow this and it will go to your water heater and to taps in keitchen and tolilet room area including a shower if you have one.
If you have a filter it is likely to be a cylinder 6 or more inches long and 2 to 3 inches diameter according to type and having two connections. It should be in a position such that it can be reached fairly readily. If you can't find it easily you probably have not got one - not unusual on a van of that period.
If you want to fit on, it should go into the cold water line before any branches to taps or tee connections (one to water heater and one to taps) such that all the water that comes in goes through the filter.
You can get disposable or rechargeable filters - personally I prefer the latter and one sgood supplier is Filtapac www.filtapac.co.uk
You buy the outer container with fittings and then subsequently just the rechage kit. Fitting is fairly easy involving cutting the water pipe and fitting the filter body in line - you will probably need two fairly small hose clips. No electricity is involved. Filter can be either horizontal or vertical but remember you have to take the top off to change the element and you will release a small oamount of water in the process. You may wish to drain the system before fitting.
936
Unless you are prepared to change it every 30 days once it gets wet they can become a perfect breeding ground for bacteria.
The water quality in the UK is very good and a filter will do nothing to improve that, but it may well detract from it.
Mar 2, 2010
1,231
19,185
Cut one open once and it was full of slime.I use a brass 1/8 BSP fitting on the pipe to give it some weight and do without a filter altogether
Jul 1, 2009
2,142
if it needs one it would be fitted if you dontlike drinking water from taps get bottled but a daimen said it is a playing field for grime also a another winter problem for drain down.
40
I'd agree a filter is not really necessary for most UK sites but in Europe particularly Spain water for showering and washing up etc. (NOT for drinking) can be pretty cloudy and this gets through and builds up in shower heads etc.
Jul 28, 2013
91
Thanks guys! Didn't realise about the bacteria bit and I'm very carefull always sterilise my water system before and after the season, won't use a filter now, (wonder why my local dealer insisted I should have one) especially at £25 a time
Jun 11, 2012
1,525
28
19,685
I have a 2010Sterling Elite Searecher and the filter in the line is unbelievable It gave all sorts of problems not only where it situated but when I did find it change it the smell was awful so I have now romoved it.The filter was block and caused me over winter problems as wellI drain down every year but tis filter didnt let me drain down properly and froze in the line causing damage If you have one get rid of it.
Sir Roger.
Jun 11, 2012
1,525
28
19,685
My post to this has disappeared
.So here I go again. I have a 2010 sterling elite searcher and my filter is now gone.It caused me so many problems and getting to it was another problem.Its behind the drawer in the centre Which has to be removed .It was only a small mesh filter so if you do have one of these remove and forget
Sir Roger
