water getting in
Feb 15, 2009
300
I have a 2013 Bailey PegasusGT65 Rimini with a water leak at the front middle window ,it is not the Black rubber seal that is leaking, but seems to be where the window frame joins to the van outer panel there is a drip of water from the middle top of window frame that lands in the middle of the floor 3" back from the pullout table also water is running down the bottom of the window frame above the pullout table .warranty should cover repair.(I hope) was just wondering if anyone else has had the same problems .and did they get it repaired /find the leak .where was it coming from .??
Mar 10, 2006
3,266
46
I had a slightly different leak to yours but thought I would post anyway as no one else has.
Mine was on the front middle window but between the window and bottom seal, and was only minor and in strong facing rain.
Dealer said they adjusted the top rail or hinge to close the window up a little more. I would ask the dealer what they think it will be as they have usually had the same issue before.
