Water heater
Mar 21, 2019
Hi all
I’ve recently bought a 4 berth touring van and I’m renovating it I’m a carpenter by trade so one internal build isn’t a problem I’m also converting everything to electric the only problem I have is finding an electric water pump and water heater I don’t know if this is one thing or two separate units can anyone help me in this
Many thanks
Gav
936
The water pump and the water heater are two separate items.
Normally the pump is either an external one which drops into an Aquaroll and pumps the water from there into the van, or an on board pump which sucks water from the Aquaroll and pumps it around the van.
They are 12vDC.
Here are some pumps: https://www.leisureshopdirect.com/water/caravan-water-pump
The water heater is normally powered by either gas or electric, or both .
To convert entirely to electric will limit where you can use the van as you will always need a hook up.
Here are some electric water heaters: https://www.leisureshopdirect.com/gas/caravan-water-heater/propex-water-heaters
