Water hog shroud
Nov 5, 2021
I’ve always used an aquaroll, and the whale pump that you plug in outside the van has a shroud that fits nicely over the exposed threads where the cap normally goes.
I’ve recently acquired a water hog 51 L barrel and really like the added volume, however the opening is quite a bit bigger and the fitted shroud doesn’t fully cover it allowing bugs and small bits of debris to get in.
For those using Water Hogs, what are you using, is there an aftermarket shroud that does the trick?
Oct 8, 2006
1,970
669
Try bags4everything at Ossett near Wakefield. They make a wide range of bags and packings, and will even make one for you to order if they don't have anything suitable. They are not expensive in the way of things and very helpful. You will even get a choice of colour!
Nov 5, 2021
Saw something similar, but wasn't sure it would stretch over the pump, and didn't really want to dismantle the pump to retrofit.
If it does the job then great find, thank you
Oct 3, 2013
890
90
18,935
Hi,
I find that when the aquarole needs filling the wastemaster is full and ready for emptying - both are 40Ltrs which is handy.
rs
Jan 19, 2002
1,672
516
I suppose in the absence of finding the ideal solution you could buy an extra cap then use a hole cutter to bore it out just large enough to accept the pump then it would be covered by the standard item
Reactions: Helinutz
