water leak connector under bathroom tap? helllp
Nov 25, 2009
81
hi- just doing the normal checkups before we go away next week - and it a good job i did - after pumping water through the system i noticed a drip noise from in the bathroom - and under the bathroom mixer tap the water was leaking from the hot water pipe that connects under the tap itself -
i forst thought it wasnt pushed in enough but that just made it worse - is there a seal that may need to be replaced or would it be the whole connector ?? any ideas at all?
ir could it be in the tap itself rather than the connector?
please help so i can get this back up and running!
G
Guest
Snap...Had a proper drip just like that, thought it was a pipe connection, but on inspection it was leaking from the cold [blue nozzle] on dismantling the nozzles are held in by a pin that runs through a groove either side of the two nozzles.The blue nozzle had a chip in the groove that clearly let water by.
We swapped the nozzles over so the blue was where the red was and vice versa, so the damaged groove was on the outside and not the inside where the pin holds them in place, and so far it seems to have work....
PS yes the are small rubber washes further up the nozzle.
Dismantling was straight forward a mere ten minute job .
Good luck
