Water Leak
Mar 20, 2011
87
10
18,585
Hi
We have just bought a 2010 Bailey Senetor California and used it this weekend for the first time, we seem to have a leak in the washroom we think coming from under the tap on the basin there is water is running down the blue pipe inside the vanity unit onto the floor even througn we turned off the pump, has anyone got any idea on what it could be. Also when the pump is running it seems extremelly noisy we had a 2005 Bailey Pagent before and you hardly heard the pump running on that'
Regards
Annie
Apr 20, 2009
5,620
1,025
Hi Annie, first question, did you buy from dealer and what warranty have you got? I had simiilar with the shower tap and due to the cold weather/frost the tap had split and was replaced with no quibble by the dealer. Sorry cant help with the noisey pump.
Jun 11, 2012
1,529
30
19,685
Hi Annie not sure of the Bailey set up but Im think all plumbing on caravans is the same .Have a lookup at the tap and see if you can see a joint where the pipe comes up to the tap make sure that pipe is pushed right in to to the connector we have a couple of these leak in the past and quite easy to repair or replace.
Sir Roger
