Water Pipes
2,190
11,935
Are you referring to a mixing valve, also known as a blending valve? If so then yes. It matters not what the caravan is, so long as it has a pumped hot and cold water supply to the taps. There are loads of valves available. All sorts of prices. some are NHS approved but tend to be dearer. I just went for a known make with good reviews. Plumbing is straight forward but reducers are needed 15mm to 12mm. Just look at YouTube, Lots of fitting videos and caravans are little different that domestic in how the go in. The biggest problem I had was finding somewhere suitable to fit it.
I did write a report on here but can't find it now. Might do later.
It’s the Alde temperature monitor valve I was considering
2,190
11,935
That IS a mixing/blending valve.
Except that neatly has the reducers incorporated but at about 3 times the price. However, it would consequently take up a bit less space. So you asked about connectors. Your standard caravan pipe should simply push straight into that one.
2,190
11,935
Look at this cheaper alternative, still a good known make and saves £24
Otherwise, I have a new Pegler 15 mm going spare if you (Or any one else) wish to dm me. Mine comes complete with isolators (Unnecessary). But a top make, currently on offer at this site.
Thanks for the info, much obliged
2,190
11,935
I thought I had posted howI installed my valve, but my forum search finds nothing. However, I have two pictures. The first is from another member who did his. His is vertical and a nice tidy job.
I could not do mine like that so had to do it vertically.
I am pleased with the results. The shower is much easier to control. I believe they should be fitted to all caravans to avoid scalding particularly for children. By the way, the paper is checking for any slight leaks.
4,231
That is what ALDE fitted into our caravan to regulate the temperature. It works quite well but one thing we noticed is that we now have to turn up the hot water higher in the mixer taps to get to the same temperature prior to it being fitted.
Jan 10, 2022
I thought I had posted hoe I install my valve, but my forum search finds nothing. However, I have two pictures. The first is from another member who did his. His is vertical and a nice tidy job.
2,190
11,935
You will, that’s because your tap is now mixing cold water with hot water, instead of cold water with very very hot water.
