I have just bought my first caravan and I think I am having a problem with the hot water, the cold is fine when you turn on the tap you get a nice strong stream of water but when you turn on the hot it starts out very strong and then in a mater of about 10 - 15 seconds dies to a dribble and continues like this until you turn it off and then after you leave it for a while it is the same again starts off strong and then fades. The pump is a Whale and when you turn it on it doesn't stop! I know I am new to this but I would have thought when it has filled the hot water tank it should stop or it will just kill the battery. Any suggestions on what to look at or try would be greatfully received.
Cheers,
Ian
www.terrileeracing.co.uk
Cheers,
Ian
