Water System
Recently picked up new van which has "shurflo" - hope I've spelt that right - water system.
The pump is contained in the van rather than being in the aquaroll.
Problem is that sometimes we turn on the tap - hot or cold and nothing happens - no water. On hot, some water might come out but then stops.
Other times it flows normally.
This happens at both sinks and shower.
Any suggestions? Is this just the way the system works? We have used it for a week and suffered intermittent problems. When it works its great, when it doesn't you are usually stuck in the shower turning the tap on and off in the hope that the system will kick in!
Dec 30, 2009
1,662
Ian, got the same pump on my van with no problems at all, it may be the presure is set too low. In any case contact the dealer to sort If you got it from a dealer
