We have a 2003 Spectrum 540 end bathroom. We had a long weekend away and noticed on the last day the bathroom carpet soaking wet. We use a carpet mat over the carpet in front of the (central) sink and to step onto out of the shower, and this had stayed dry, so hadn't noticed any build up of wet beneath.
First assumption was the sky light as it had rained quite hard, but this was closed and had not been open (carpet mat would have been wet!). The water looked as though it had spread from below the central sink, but had soaked the carpet as far as the drawers and nearly up to the toilet base (offside).
On return we dried out the carpet and I proceeded to check for leaks in the drain pipes from sink and shower, and also the hot/cold feeds, what we could see of them- which isn't much. Despite leaving the shower/sink on, and using several tanks of hot and cold water, wastemaster full, absolutely no sign of leaks.
I had thought that a full wastemaster may have caused the waste water to 'back-up' through the pipes and above the floor level and then maybe seeped out somewhere; but testing this again couldn't simulate any water ingress. No sign of any wet areas beneath the van externally. A real mystery.
Anyone had similar experience or any theories?
Mark
Mark
