Whale pump failure
Mar 2, 2008
Just been away, terrible time, one thing after another. Final straw, Whale pump started blowing the 10 amp fuse (pump fuse) after only a few seconds pumping. Got through 5 fuses in as many minutes, then gave up. Took the pump to Highbridge caravans, tested it across a battery (no fuse) said it was fine and to check wiring in van. Did so, all fine. Tried a 15amp fuse (silly I know) and pump now dead (unsuprisingly) Does anyone know what cause could be. Was it a faulty pump after all perhaps shorting out, cos it wouldnt blow a fuse across a battery would it? Came home early, couldnt ace a week without running water. Please help.
4,269
Paul,
have a look at " Whale Pumps Representative" page 2 under Equipment and accessories. You get can contact Whale's Martin who may be able to help you.
"MartinMcc@whalepumps.com"
How old is your pump?
Chers
Alan
Mar 2, 2008
Paul,
Chers
Alan
Pump may be 7 or 8 years old, caravan a 2000 model pageant
