I am regular DIYer, including plumbing, but not caravan-er - my neighbour has Bailey Pageant S7 Loire, used as all year round accommodation since Jan 2022 for one additional family member, so think just light water use, not showers etc. No water problems until early this year, but now blows 10A pump fuse on regular basis. (Possibly started with a freezing night?) {note - on pump says 5A, fuseboard says 10A ??}. Water supply is mains to 40 litre Aquaroll with Whale EP1612 pump. Aquaroll currently not insulated, but planned before next winter. Mains electric.
I have replaced about 6 red 10A fuses; each time I turn tap on few times to test, water flows fine, (inc a 5 min run) does it's 30 sec surge dump run on (I understand that's ok), so assume all ok, then couple days later am told fuse blown again. Last fuse replacement lasted couple of weeks. EP1612 pump replaced in case froze and run dry; no improvement. Ballcock in Aquaroll works fine. No pipe leaks in caravan evident. Whale Smartflo UV0814 pump in caravan all seems ok. Have asked Whale - response unhelpful.
So it has worked fine for a year, works fine when I test, but since mid winter blows fuse for user, with no changes/alterations to the system?? Confused. Could there be anything else I should ask the user? I had initially suggested switch pump off at caravan door each use, but later said perhaps leave on as that could affect something.
Thanks in advance
Thanks in advance
