Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Have you looked at your hand book and the numerous videos on line ?
According to an AI response it says:
AI Overview
The overheat thermostat on the SH2012 B should be set to 90-100°C (194-212°F). This setting prevents the appliance from overheating and potentially causing damage or safety hazards.
Explanation:
Overheat Protection:
The overheat thermostat is a safety feature designed to cut off power to the appliance if the temperature exceeds a certain limit.
Specific Settings:
The recommended temperature setting for the overheat thermostat on the SH2012 B is typically between 90-100°C (194-212°F).
Importance:
It's crucial to use the correct setting to ensure safe and efficient operation of the appliance.
Hopefully someone may know your specific model and advise. But as this is a safety critical issue you may do better to speak direct to Whale after the Easter break.
