whale tap problem
Apr 28, 2010
Our cold tap just keeps turning round and round. Is it the thread that's gone and if so, does anyone know how to fix it? We are caravan newbies.
Apr 28, 2010
The spindle has broken and it needs a new tap top.
Pull the old one off and inside the center of the spindle hole you will see the remains of the old spindle.
Use a long chipboard screw to just go far enough into the old piece to enable you to pull it out.
New tap tops and spindles can be found here:
]http://www.leisureshopdirect.com/caravan/water/Whale_tap_accessories.aspx
http://www.leisureshopdirect.com/caravan/water/Whale_tap_accessories.aspx[/quote
Thanks very much for your very usefull response. A new spindle and tap top it is then. Thanks again.
