Hi, I recently posted a problem we had with very poor water pressure on a Bailey Pageant Majestic 1988 model. This problem was on all taps both hot and cold. There was a new pump fitted last year which has not solved the problem. i've looked at all pipe work to check for kinks and faults - all seems OK! Whilst checking all pipe work and point of entry into caravan i noticed a whale pressure switch of which the water travels from pump thru filter then into this pressure switch before splitting to either hot or cold system. This switch also has a knob on the top which can be turned, I assume to alter your pressure, so I tryed turning in both directions, however there is no difference in water pressure. I have also noticed the pump every so often whilst all taps are closed keeps firing up for a few seconds as if it is pressurising up! Is this normal or does it sound as if the Pressure switch could be faulty? I still need to flush water pipes for descaling and to renew water filter but wanted to rule out the pressure switch 1st. Any advice or comments appreciated, Many Thanks, Andrew.
