Wheel Nut Torque
Sep 26, 2006
153
Hello all!
Does anybody know if the correct torque for alloy wheel nuts is 98Nm or not?
I rang the local service centre and they spent five minutes scurrying about to find the correct setting, looking in manuals etc which I find rather worrying as they spend all day removing and re-fitting wheels !
Thanks for any replies.
Nick
Feb 17, 2007
699
Think yourself lucky Nick. The reply when I asked the same question about my car wheels at the dealer who sold me my Kia was " Tight, very tight. " Mind you they also gave me a printout that stated wheel studs are designed to stretch under load! I have changed to another garage.
Sep 26, 2006
153
Thanks Eddie,Mike - wise move by the sounds of it.
Other quotes I've had are 110Nm and 100Nm so it seems it's maybe open to interpretation.
Surprisingly AL-KO say 88Nm but don't specify whether that is steel or alloy wheels.
3,595
Hello Nick,
With a specific question like this, and as it is safety and vehicle construction and use related, it should be directed to the supplier, the manufacturer or a source with the authority to give it..
You should not rely on information supplied through this forum. Whilst such forum advice may not intentionally be incorrect, but it might be wrong and result in a failure.
Hi Nick, The wheel nut torque given by Eddie 115nm is correctfor alloy wheels.
For steel wheels the torque is 88nm.
The above information is given within every new Bailey Caravan owners manual page 2-11.
Royston
JTS
Jan 16, 2007
273
Hi Nick, I have checked the manuals and EDDIE and ROYSTON are spot on. Watch the tightening sequence. Tighten one go to the opposite, move to the next one then the opposite. If you have 5 nuts leave the 5th one to last. JTS
