- Jun 16, 2020
- 5,848
- 2,770
- 17,935
Hi John would a Y junction work to my double drain away caravan waste pipe adapter in the photo below![]()
You need a 32mm push fit tee (or ‘Y’) junction and a short length of 32mm pipe. Simply pull, apart your present 2 entry adapter and add the ‘tee’ in the middle. Spacing can be adjusted by using a slightly longer pipe. But, the problem MIGHT be that the spacings are too far apart. If that is the case. Then it might be possible to adjust the brackets on the van to suit.
This is what you will end up with and they can be purchased ready made.
