Where's mi Grommet Gone? (Newbie)
Feb 3, 2008
31
Hi
I won't bore you all with the details but I had reason to remove the rear light assembly from my caravan and on replacing it nicely lined up all the holes with the screws. However one wouldn't screw back in and on removing it again, the rubber grommet (inside which I'm assuming there was some kind of thread) had pushed through onto the inside. Can you get a replacement and is it easy just to push them in or is there some other ingenious way you can provide a thread for the screw to go in, bearing in mind the acrylic skin is only quite thin.
Thanks for your help
Sizzler
andy
you can get the same sort of thing from car dealers but usually need some sort of pattern. you can also try a household rawlplug come in variouse sizes so one should suit
dave
JTS
Jan 16, 2007
273
Andy, you need a caravan cavity wall fixing. Most good caravan accessory shops sell them - between
JTS
Jan 16, 2007
273
Andy, if that link did not work try EBay Item number: 180171629124. Good luck JTS.
Feb 3, 2008
31
my dad in law just did the same thing and the dealer has provided some grommits.
jo
Hi
My dealer suggested 'plaster board fixings'........but then again that's why I thought I'd ask the people who really know. Thanks
Andy
