Hi all,
Normally the higher the torque the better the tow vehicle, a diesel as any modern engine can have a small torque band and to get the best out of it more ratios can be used, a Cummins M11 engine as fitted to a number of HGVs will pull 44 tons at 56mph at only 1500rpm in 16th gear, pulling this kind of wieght requires lots of torque and little bhp hence the diesel engine and 16 speed box, there are no recent petrol HGVs because they lack pulling power compared to diesels, HGV engines have the same technology as cars except they had it first, Cummins used common rail on the L10 engine over 20 years ago and still do but they still have a narrow torque band needing more gears, a lighter vehicle such as a car fully loaded towing a caravan will benefit from more gears like a HGV so the engine can run at it's maximum torque, this can improve perfomance and economy. A petrol engine can produce reasonable torque but gives more bhp, they can hold gears for longer due to them revving higher and size for size are usually quicker but will not pull the same when left in gear towing.
spj.
spj.
