Having been called out to a couple with a motorhome in which their fridge would not work on 240v, I set about tracing the fault only to be potentially killed as the supply for the fridge instead of being from the No3 MCB (which was marked as fridge supply) it was from the No2 MCB which was only marked as Heater.
Not only that, but they had fitted an isolation switch inside a wardrobe, but make no mention of that switch in any of the van literature, nor is the switch marked in any way.
After spending this summer mainly on different sites, fixing a lot of warranty jobs, I can understand why so many people are fed up with build quality.
On another caravan, less than one year old I still have to return to fix:
Table, as it is like a roller coaster instead of flat.
Alarm, never worked from day one, now has to be removed and a new unit installed.
Status 530 with fault in mast head, along with 6 out of the 7 terminal connections badly made allowing the outer braid to contact the inner core.
Cutlery drawer, which is 1/4 inch wider at the rear , allowing the drawer to fall off the runner when closed.
Wardrobe base held in place on 4 flimsy plastic pegs, which have collapsed.
Waste pipe from sink which is so badly kinked where it turns that it has fully shut off the pipe causing the sink not to be able to drain.
The vehicles concerned are not both British built either, one is , but the other is German, so no commonality there.
If only they could all get their acts together and provide decent quality of fitting out, it would save customers so much less trouble and bad feeling.
