Winding Tubes
May 22, 2006
266
I would like to know if anyone knows where to obtain the corner steady metal winding tubes I`ve seen on so many vans, not the plastic type that Al-Ko sell (too exspensive). Failing this I will have to make up my own.
May 22, 2006
266
No sepperate part, tube is welded to an angle piece that has two slots in it to locate between floor and steady mounting plate. Loosen the two nuts and it slides out (to the rear). These are made by some firm don`t know who, and not fitted to every chassis/caravan
Sep 14, 2008
39
Terry
you could always try some waste water pipe if it is the corect size to slide your winder through from B&Q, attach it with silicone sealer.
Donb
