Hi.
I have a 2003 Fiat Ducato Swift Lifestyle 590 RL.
Two of my window blinds are not fully retracting up to the top and would be grateful for your help please.
Ive watched videos on You Tube but im puzzled with the final stages.
Ive removed the 2 end caps.
Removed both side guides the removed the whole blind and placed on a flat surface.
I understand that the top screw is for the fly blind(they work fine) and the bottom one is for the main blind.
I can see the little plastic thing inside the hole with a slot for screwdriver.
Do I have to take out the plastic thing and wind up the long metal bar to re-tension....im not sure as I dont want to force anything in case I break it.
Also....to carry out the re-tension procedure...does the blind have to be fully pulled out....half way or wound right up.
Your help would be much appreciated please.
Many thanks
Many thanks
