Window leak
7,404
I had a Series 5 Pageant Bordeaux and it’s near side small front window developed a leak through its seal. Had all three seals replaced. The caravan was 9 years old when the leak occurred.
4,266
Fully open all the front windows and thoroughly clear out the debris that collects in the top Channel. This is the first port of call for a leak. Still leaking? Clean the window contact area and rubber seal with silicone spray. Still leaking replace the rubber seal.
3,573
Dusty Madtaffy , stated the seals have been replaced, , have to rethink , maybe a very small crack in the window. ?
Jun 17, 2011
826
27
Where does the water seem to come from. I had a leak that looked as though the water was coming up from the bottom. The catch needed tightening slightly. The test was to push a piece of printer paper between the seal and the caravan. It shouldn’t go in. Apparently it is that critical.
4,266
Oh no he didn’t. Oh yes he did. Oh no he didn’t! :p
Too much jungle juice :eek:hmy: ;) :p
3,573
If in doubt, :unsure: just reply to what you "think " you have read.
Sorry. :whistle:
4,266
Sorry. :whistle:
No worries.
It is pantomime season :kiss: :kiss:
Nov 21, 2018
If you do need some new trim then give us a go, we've got 200 different types so hopefully one wil l fix the problem B) https://www.edgetrims.co.uk/ We've got a code for Practical Caravan users as well, if you enter TRIM10 at checkout you'll get 10% off. Hope we can help
