Yet another jacking question
Sam Vimes
2,831
2,304
12,935
The advice I came across when preparing to jack up my caravan was to do it with it coupled up to the car. I'm wondering why this should be.
I can see that potentially the jockey wheel could be lifted off the ground but this seems unlikely to me given that in my case there's a nose weight of 75kg pushing it down and the jacking point is way back at the axle.
The reason this has come to my mind is that I have to take both wheels off to take them to have tyres fitted. I've got the spare on one side but I can't see any reason for not leaving the other side on the jack and the caravan not connected to the car - ensuring the jockey wheel is in contact with the ground. It will still have three points of contact.
Nov 30, 2022
2,020
1,920
5,935
If you jack one wheel off the ground, even if the brake is applied there is a real danger of the caravan pivoting around the the opposing wheel. The jockey wheel ISNT braked so can/will rotate AND swivel.
Hence the advice to only jack when hitched to a towing vehicle. Entirely logical if you think about it.
Jan 20, 2023
1,327
1,181
5,435
It's surprising just how easily a single axle caravan can do that, my drive is completely flat but the caravan starts to slew round very easily. I now have a driveway security post which I attach the caravan to before jacking.
Reactions: RogerL
9,647
If like you I needed to take the two wheels to have tyres fitted I put the caravan nose against a house wall, and being extra cautious I placed a breeze block either side of the jockey wheel. Could have just wound the jockey wheel in to its slot I guess as an alternator option to stop it rotating.
3,918
The jockey wheel has no sideways stability - once the jacked wheel is almost clear of the ground, the caravan is free to rotate sideways using the other wheel as a pivot, which may tip the jack over - especially the Alko sidelift jack or a simple bottle jack - got the T-shirt!
It doesn't seem to be a problem with a trolley jack or a heavy-duty air jack as used by many mobile technicians.
Sam Vimes
2,831
2,304
12,935
Good points, thanks. I do use a trolley jack and planned to wind the jockey wheel right down and put some wood around it but......
Plan B is to try and see if my car space saver wheel will go on the caravan.
Plan C is to take them one at a time.
Sam Vimes
2,831
2,304
12,935
You will STILL need to jack your caravan up to fit any spacesaver wheel.
And there's me thinking I could fit it without jacking it up😉
The point of using the space saver is that I can jack the van up with it coupled to the car. Fit the space saver then let the van down and then uncouple it.
Drive carefully to garage avoiding potholes and sheep.
3,918
If you can find some wooden blocks that would support the caravan axle end plate, you could jack it up attached to the car, remove the wheel, drop the caravan down onto the blocks and then unhitch and take the wheel to the workshop - with the reverse when you need to refit it.
Jan 20, 2023
1,327
1,181
5,435
Does Spacesaver have same PCD and fastener diameter holes as caravan?
Unlikely as both the PCD and centre hole will probably be different, plus a space saver isn't designed for the additional load of a caravan. Back in the 90's my uncle had an adaptor for his caravan to allow his car spare wheel to be used, no idea where it came from but it was a commercially available product.
9,647
My XC70 Space Saver was rated okay for towing with the recommendation that it be fitted to the front of the car. All my other tow cars had full size spares but not necessarily identical wheel diameter or material to the OEM alloys IE Skoda Superb AWD estate.
