Hello
I have an Abbey Archway Royale (also says swift somewhere) and having some issues with the 12v
I have 2 round ceiling lights ( front living, middle over the fixed bed and rear bathroom) and 4 spot lights. They all have the little 12v 2 pin led bulbs. The middle round light turns on. None of the others work, except for a small flash on each one as I turn on the main fuse after turning it off. This is also true of the 12v car cigarette style charger port.
It happened twice and resolved when I disconnected and reconnected the ehu. Then it happened a 3rd time and hasn't resolved since. The bulbs all appear fine. Ive changed the hookup cable and the hookup location and the issue persists. The clicker on the oven is also not working.
I have swapped bulbs about but it remains that only the one light above the bed works. The others do not flicker if I use their switches. Its only when I flip the main fuse switch on their MCB.
I also have to keep the battery charger switch on even though I have no battery connected.
Any ideas? I can't see any reason why one of the ceiling lights would be on a different circuit but it's the only one working. Distance from the fuse board it is the closest but I have no idea if it is wired there first and not sure how to get the electrics diagram.
Its a 2005 abbey archway royal elegance but also has swift written on it somewhere too? Not really sure what that all means.
Thanks for any help.
