12 v electrics
The 12v electrics on our van stopped working - absolutely nothing. (Fortunately I was only doing a few jobs on it at home)I plugged in the mains lead and the mains side of things worked fine. I assumed that through the charger the 12v side would work but again nothing. I removed the battery and charged it overnight using a mains charger. After replacing the battery the 12v side worked fine.
My question is... why didn't the 12v side work when the mains were connected? Does the battery have to have some charge in it for it to work through the mains? (I think the battery was very low)
Catcher
Sep 30, 2006
208
As the battery was completely flat the caravan charger would probably stop working (shut down)as it can only supply around 12amps, hence no 12v on your van. By charging it overnight the battery would not need such a high current to charge it and the van charger should maintain it now.
Ron
4,220
Hello Catcher,
Further to Ron's suggestion, If the battery was so low as to cause the charger to limit and stop running, then the battery could be damaged.
However there are some other possible causes. Most chargers have an input and output fuses to protect the wiring in the event of a fault. If a fuse has blown, then the battery will not charge.
If the fuses are ok, then the charger may be damaged. To check:
Disconnect the battery, (Make sure the battery leades do not touch each oterh or any oterh metal parts to the caravan). Turn on the charger, and see if any of the 12V lights or fans work. If they do, then the charger is ok. Tuen every thing off and reconnect the battery.
If the appliance don't work then the charger is likely to be faulty.
John, thanks for your reply. I must admit I was wondering about the charger. We've only had this van for a few weeks and the thought did cross my mind as to whether it was working properly. When I had the problem I found a fuse near the control box. It was a very old looking fuse in a brown plastic (bakerlite?) holder that looked much older than the van (1999). The local caravan dealer had never seen anything like it. When dismantling it I broke it (it had fuse wire in it) so replaced the whole thing with a new holder and fuse. The van is still under warranty so I will check it as you suggest before contacting the supplying dealer. I can't help thinking though that the test you suggest would be the same as having the mains connected with the flat battery as in my original post and the 12v side didn't work then - or am I missing something?
936
Catcher, some vans will not work on 12v if there is no battery connected, they are an integral part of the system.
To check if your charger is working, with all electric off, measure the battery voltage.
Now turn on the 240v and make sure the charger switch is "on", then measure the voltage atthe battery terminals.
If there is around 13 to 14 volts, the charger is working, if no difference, its not.
4,220
Hello Catcher,
Yes there is a difference, and your last note added some useful information. As the caravan is post 1998, the system in the caravan will not be a simple charger, but a more sophisticated beast called a regulated power supply.
Prior to 1998 many caravans used a relatively simple battery chargers. These produced an unstable dc current which could have voltage peaks as high as 22Vand lows of 0V. If these earlier systems were used without a battery, some sensitive appliances could be damaged by the voltage spikes. A battery was needed to provide current and voltage smoothing.
The modern power supplies can be 'intelligent' to the extent that they can sense the load they are connected to, and if it is too current hungry, they shut down. - So if your battery is faulty, then the power supply may be reacting to it and turning off. By removing the battery, you are eliminating that part of the system, and the power supply may be able to function satisfactorily and run some of the 12V appliances in the van.
That will at least prove if the power supply is working or not.
I have to point out though, my suspicion is that the supply is not working or an associated fuse has blown. This is partly supported by the apparent non-standard fuse installed. This suggests that a previous owner has had a problem of some sort.
Many thanks for the helpful replies. I have tested the voltage at the battery with mains disconnected and it read 12.66 volts. I tried it again with mains connected and it still read 12.66 volts. This would suggest that the power supply is faulty doesn't it (or could it be the intelligent charger shutting down)?
The power unit has 'Power Centre II' on it and the only switch (apart from 4 circuit breakers) is an un-marked rocker switch which I presume is to switch between car and caravan battery. I might just try your last suggestion John of seeing what happens without the battery, but not tonight!
Regards
Catcher
936
Catcher, by not having an increase in voltage at the battery with mains on indicates that either the charger is not working at all, or there is a break in the cable or fuse blown, but it is unlikely to be a fuse as there normally is not one in the charging cable from the charger.
When you put power on, you should have had at leat 13.5 volts at the battery terminals.
Thanks for all the replies. I've decided the charger is definitely not working. As the van is still under warranty it will be sorted by the dealer.
Regards
Catcher
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
SGDGHDH
