12 volt system
Hi
I have a bailey Vermont which has developed a faulty 12 volt system
The gauge which shows the power of the 12v system does not seem to be working.
The charger is warm and you can hear it buzzing but nothing shows on the gauge
All the 12 v system seems to be working ok
So is the gauge gone faulty and need replacing or some other problem
Robbie , are you on a electric hook up as when ours went in France our amp guage went down to zero on our Baileys but we still had 12-volt usage until we realised what had happened, charger had burnt out so check your charger.
Yes it looks like the charger has failed so have it checked out. It should not be making a noise although some can get a bit warm at times. If it is hot though I would disconnect it.
