12 volt
Jan 17, 2021
16
7
15
No worries nothing has been touched just got the person to look at it and confirmed no 12v coming into the van
Thanks for everyone for all the help
Will use this forum again for any future queries.
Oct 8, 2006
2,101
757
As the first two years of a three-year caravan warranty are with the manufacturer (third year is usually with the dealer,) if Covid regs are causing you a problem a Caravan Workshop Approved Technician should be able to resolve the issue under warranty problem and will go to your caravan wherever it is to do the work, assuming mains is available there.
4,800
Unfortunately no power at the Storage just have to wait until the dealership opens up here scotland
There is the possibility, that the dealer could send out a technician to check your van in storage, or the dealer 'might ' get a AWS tech to check your van out. The mobile guys have 240 volts supply on their vans.
Just a hope.
Mar 10, 2006
3,274
47
You need to use the App to monitor the battery voltage.
I use mine every day, 12.4v is no problem IME provided a solar panel is fitted to bring it back up.ll
Oct 8, 2006
2,101
757
What app? Bailey stick with old fashioned analogue or now more modern digital meters - but no apps!
Jan 17, 2021
16
7
15
Assuming your battery is okay then I would go back to first principles switch every thing off and try and restart the system in accordance with the handbook. Using its fault finding guide if required. There have been posts on the a forum about how to reset the Command panel if it malfunctions. A search will find them using keywords “ command panel” there are lots of hits.
I added my comments to let all know that the main cable had come out and I had been fixed at the dealer all e
This has been rectified as per my previous post
Reactions: Parksy
