I know this used to be a common problem and it seemed I had cured it on our Shogun/Wyoming by always widening the centre pin on the caravan grey plug before connecting, but noticed that both the centre pins on car and caravan had started to melt the plastic again. I have replaced the plug on the cravan no problem. I have replaced the one on the car and in doing so noticed the centre black earth lead was poor cotact due to corrosion and not enough insulation removed from the wire.This was original fit when tow bar was fitted by fitter.My questions are;
As the white earth lead is thicker than the black would I be better to swap the white for the black to get better earth, or could I join the white and black earth leads together to improve the earth, if so is it better to bridge between them, or replace with one heavier duty wire connected to both terminals and taken back to an earth point seperate from the grey cable.
