Swift Awning Light Replacement.
Sep 2, 2023
102
69
635
So after about 6 years 90% of the LEDs have finally failed and I see that the 'sealed' unit is full of water / condensation which seems to be an issue with all of these lights, so its time to replace the unit for about £70.
Its a pretty straightforward repalcement job as they appear to fix to the wall of the caravan using double sided tape. I've looked at the existing unit to be repaced and its stuck rock solid to the van and will not budge. Even when I try to ease it feels as if its fixed with screws - which it isnt.
I dont want to apply heat to soften the tape or use a stanley knife to ease it off and risk damaging the outside wall of the van (as a member on here has already done), so I'm wondering how might be the best way to get the old unit off without making a real mess and wishing I'd never bothered!
Has anyone changed their unit as they all fill with water and fail and are a very very common light.Awning light.jpeg
7,433
I used dental floss with a gentle sawing motion and patience. Some warmth helps and with care a hairdryer isn’t going to damage the caravan as the heat applied is far less than it sees on a hot summers day.
Reactions: toad a caravan
Sep 2, 2023
102
69
635
Woodsieboy, I found the video on YT and its brilliant. A bit of a fiddly job but very straight forrward as I've already changed the touch screen panel so are familiar with whats waiting behind. As ever, just a question of not rushing it.
Thanks guys for all your suggestions!
Reactions: woodsieboy
