Hi All,
I have all the necessary outputs from the car grey socket and all still live when I check the grey plug (tested by avo meter with outer cover removed) but when I check the fuse panel in the caravan there is no 12v input. One of the cables is the live from the grey lead and the other end of the fuse is a wire going to a relay, to that end I have no battery charging or lights or electronic cooker ignition with the grey socket plugged into the car, be it running or not! Is the relay at fault?
Advice appreciated
Regards Kenny
Advice appreciated
Regards Kenny
