12v fridge problem
Sep 22, 2009
5
Hi
Just had new 240v element fitted and had fridge checked out,12v-240v and gas, everything ok until hooking up, fridge light switch comes on intermitently, at a regular pulse, could this be a fault on the car or van, new towbar and electrics fitted Sept
Help please
Mar 10, 2006
3,274
47
sounds like the voltage sensing relay in the car wants adjusting, or a poor connection.
Ask the towbar fitter to check at the 12s socket/ 13pin.
Feb 14, 2007
83
Agree with Ray.
Sounds like the car tow electric relay for the fridge needs adjusted. Should have been set up by towbar fitter. Normally switch point is set to around 13.6 volts, so only puts power to fridge when engine running.
Jun 11, 2012
1,536
33
19,685
Geoff I had this problem some time a ago with a smartcom relay from towsure,this turned out be very simple and that was the earth on tow vehicle and plug I hope this helps you
Sir Roger
Sep 22, 2009
5
Many thanks for all the replies, have contacted the towbar fitter and just waiting for him to turn up, you would think these guys would know by now
Again, Many thanks
Jun 23, 2008
159
Do you have 13 pin socket? I have had problem on my Audi with factory fitted!!! (2nd mortgage job) towbar & electrics and pins 10 & 11, the fridge supply are not connected, did not find this out until changed van with new fridge that has digital display telling me no 12v power source.
Just don't understand how these car people think, they sell cars with various limits/loads/ technical data etc on towing and offer tow bars/electrics but do not appear to understand what is required. It would be bad enough if I had taken it to the 'two bob tow bar man' but Audi Vorsprung Durch Technik for heavens sake.
My Audi dealers are trying to sort it out.
Bill D.
Oct 22, 2009
78
Reminds me of a Joke about "the four spring duck technique", sorry can't repeat it here.
