12v Fuse keeps blowing
Jul 26, 2008
We are having issues with our van, the 20amp fuse at the battery box keep blowing.
I have tested the electrics and seems that the +ve is earting out somewhere.
Anyone have any ideas where to start tracing the fault.
James
Apr 6, 2008
71
Hello Frank
Before I can give you some ideas as to what is wrong could you please say what and how you have tested the electrics,and also what caravan you have.
Roy
Jul 26, 2008
The caravan is a 2004 Ace Twinstar. I have disconnected all connections from the Main Panel and performed a continuity test between the 12v input from the battery and the earth wire, it seems that the +ve is grounding out somewhere in the van.
I am looking at the best way of tracing the fault. I was thinking of testing the +ve of all 12v circuits into the fuse board to try and isolate the circuit/appliance. Will this approach work?
James
Jul 26, 2008
James
Meant to say test the +ve of each 12v circuit for an earth leak
Jul 26, 2008
An update, seems that the previous owner had reversed the polarity of the cables from the output of the fuse to the control unit.
Thanks to a Circuit Diagram with cable colurs from the Sargeant website I switched them to the correct polarity and lo and behold all is now working as expected.
Thanks for your help Roy
James
Apr 6, 2008
71
James
Hello James
Sorry i have been out until now and was just about to reply,i am glad you have sorted out the problem,its alway`s best to figure it out for yourself in the long run,as i found out when i had a problem with my water pump,since then apart from the gas i can fix any problem that i get with my caravan.
Regards
Roy
Jul 26, 2008
I would always prefer to attempt things myself. I usually find working methodically through usually gets to the bottom of things
