I've brought at Swift corvette diamond 1990 or more likely 1991. If you have a detailed manual or hand book, I'd really appreciate a link or PDF copy.
The electrics are providing a challenge. Mains hook up, fine and powering as expected.
12v system is odd. The two spot lights above the front seating/bed area work off the 12 supply, but all other 12v systems are not working.
Exploring fuses, which appear to be fine - but will replace today as a matter of course. One worry at 35A fuse was located in a 10A screw in fuse housing!
Read the forum on charger, but that appears to be working.
Problem: No water pump function, no external light, not all lighting working....
So the question is have I missed anything, as I suspect fuses are not the issue!
Known history:
- water heater is defunct, needs exploring but disconnected
- battery was flat, but charged and holding 12.8v (supposed to be new in the last 2 years, have seen same model on sale.)
Known history:
