- Jul 18, 2005
- 125
- 0
- 0
Coming back from holiday today and the cable from the caravan 13 pin plug came loose and was trailing on the ground. By the time i discovered it the friction had worn through the outer casing and some of the wiring rendering the cable usless. It is only approx. 6 inches from the plug, can i cut the damaged part off and rewire the plug ?. Any help appreciated.
