16A Blue mains connectors
Aug 17, 2008
236
Not strictly caravaning but as I've always had great help and advice here I thought I'd ask anyway!!
We have just bought a static on a new site and over the weekend went out to check a few things out and noticed that the mains input box which connects to the van via the normal 3 pin blue connector which I thought was rated at 16A has a 32A breaker fitted? Looking inside the van there is a a 20A and 2 6A breakers so adda up to the 32A at the box BUT is this right? I always thought the blue caravan connectors were only rated at 16A?
4,465
Hello Len,
The standard caravan EHU is rated for a maximum of 16A, but there are 32A versions which are also blue, but if you look carefully it will not be compatible with the 16A versions
see
https://www.studiospares.com/Cables-Leads/Mains-Components/Proel-Ceeform-32A-Plug_437400.htm?CAWELAID=120173110000123577&CAGPSPN=pla&catargetid=120173110000086129&cadevice=c&gclid=CKOjl5XEosoCFQMcGwodY-oAeA
Mar 13, 2007
1,750
hi Len, sorry I missed this, not that it matters as the info received is correct,
the plug will be Blue as this denotes single phase 230v but the 32amp plug will be bigger as will the connecting wire.
a 110v plug would be Yellow, and a 440v 3 phase plug Red just in case you ever wondered.
