2003 Ace Award Transtar Replacement Battery Charge
Mar 25, 2018
Good evening, I really need some urgent advice, please. I have a 2003 Ace Award Transtar and the battery charger unit has gone capput! I need a replacement urgently but do not know what unit would be a straight replacement. Can anyone help? Is there any way of attaching a phot of current unit?
937
In the absence of a picture can you tell what power system you have, or any markings on the charger itself?
Mar 25, 2018
Hi Damian, it’s a Plug-In-Systems ESM. It has the battery charger switch at the top and the mains breaker below with 3 other breakers. Next to this charger unit you have a separate board with the battery condition gauge and the van / car switch, aux switch and water pump switch. This says ECM on it. Hope this helps?
937
Thanks for that.
The very best person to talk to is Paul at Apuljack Engineering.
He will go through some things with you on the phone and if needed he can repair your current unit to better than new, but at a lesser cost than buying new.
http://www.apuljackengineering.co.uk/
