2015 Coachman Vision
Jan 15, 2023
13
Hi to everyone,
Just wondering if anyone could advise me where could I buy bathroom roof light blind for Coachman Vision 520 ?
Thanks in advance
2,747
Chances are it is very standard, prize it out and take some measurements. Then the internet, or any dealer. If it's halogen, update to LED.
IGNORE THE ABOVE. SENIOR MOMENT.
2,628
You need know the dimensions of this bathroom skylight and then google Seitz skylights you should able to find one
5,362
I seem to recall that you cannot buy the blind on its own and you need to buy the part of the unit that holds the blind, but I might be wrong. You could also have a look at caravan scrap yards.
Reactions: Daren225
Jan 19, 2002
1,710
551
I would guess that with age and use the silvery backing begins to look porous against the light. The question has been raised on here before and I can’t recall if a solution was found! You can buy concertina blind fabrics for example for conservatory windows but I think the pleats are deeper and would not fit the aperture. Replacement of the unit is expensive!
4,672
You are wrong , you can buy just the blind on its own ,I will troll the dealers for the info.
2,628
Just remember when we got the Abbey caravan the blind was knackered our caravan engineer got me a replacement for £80
5,362
When ours went faulty on our Lunar Delta the dealer replaced the part of the unit where the blind is fixed, but obviously it depends on the brand. It was a warranty job so may be different.
Also when all three front blinds packed in on the same caravan when it was brand new and before we had even signed on the dotted line, they completely replaced all three. Luckily we were forewarned that there was an issue with blinds for that era so checked them all before signing. Probably got that good advice off this forum.
