- Sep 23, 2023
- 1,020
- 386
- 1,435
No he didn't. Continuity error. I was responding to the OP (toadacaracan) who didn't say anything about where he had seen the trip fuse. Mr Plod snuck in a reply before I posted which is why you're confused.Read his post,,he says the big river.
Oh yes he did! And I'm not confused.No he didn't. Continuity error. I was responding to the OP (toadacaracan) who didn't say anything about where he had seen the trip fuse. Mr Plod snuck in a reply before I posted which is why you're confused.
Oh no he didn't! (he's behind youOh yes he did! And I'm not confused.
I'm considering fitting one of these,it a trip fuseView attachment 8679
Post #2 was from Mr Plod. As I said, I was responding to the OP (Post #1 from toadacaravan). Are you familiar with the abbreviation 'OP'? 🙄Post 2, you are to 🐌 slow
I was thinking along similar lines, but also it's not the sort of item I'd want to buy from a questionable source.Ignoring the issues of did he, didn't he, and where the fuse/breaker might be located, these resetable devices can sometimes be more sensitive than a cartridge fuse. of the same apparent rating.
As such if you have been plagued with fuses blowing , then there must be a reason for it and if for nothing other than safety, the cause of the fuse blowing should be resolved.
If you don't resolve the cause, your more likely to need to reset one of these devices more frequently.
12 Volt planet 👍I've never seen these before. Can you link to where you bought it?
Is it in place of a fuse that blows regularly?
Certainly not a cheap option. I carry a fuse kit with 100 or so fuses of different sizes that cost less than half the price of one of those plus delivery.12 Volt planet 👍
