- Jun 29, 2007
- 41
- 0
- 0
Going to France in 2 weeks. Question is, can you use a standard UK hook up cable. And also the site is 6amp will the water heater be Ok on 6amp. What on average can you run in the van on such a low voltage.
Paul, I think you are mixing up your volts and amps. The voltage is nominally 230v and the Amps ( current) can be 4 ,6, 10 or 16Amps. On some sites I have been to they put a different fuse (MCB) in the pitch supply depending on what you want and you pay accordingly. The UK type connector is becoming more common but a lot a sites will be the French standard. You can buy an adaptor before you go at most caravan shops, Towsure have one in their catalogue no C59 at
Paul,Paul, I think you have a Truma fitted. It only holds 14 litres of water and the element is 850W. The 1kw and 2kw settings you refer to are the space heater and I hope you will not need that!
Ray
hi there Paul.....Thanks for that. But the water heater is 2 KW (8 amp ).
