A big concern
5,009
Initially I thought it was an April Fool joke, but a Google shows that it is a big concern for planet earth. Apparently, some scientists have the crazy notion of dimming the sun by aerosol injection
The most common proposed method involves injecting tiny reflective particles, like sulfur, into the stratosphere using high-flying aircraft or balloons. These particles would reflect a portion of the sun's rays back into space, reducing the amount of solar radiation reaching the Earth's surface. By reducing incoming solar radiation, the planet's temperature would decrease, potentially mitigating some of the effects of climate change.
The opinion is that this could cause changes in rainfall patterns, damage to the ozone layer and disruptions to global climate systems. Some argue that solar geoengineering raises ethical questions about who decides to implement it and who bears the potential risks. Either way, when mankind interferes with nature, the consequences can be disastrous!
If unsure, Google "Scientists want to dim the sun". A frightening experiment in my opinion.
2,092
Anyone watched the Snowpiercer TV series?Fiction but exactly the scenario Buckman envisages.
Hopefully too crackpot and expensive to ever proceed.
1,286
1,142
2,435
I marvel at science, I really do, history shows some of the radical concepts that have become accepted into everyday life. Unfortunately the side-effects of some of these concepts only get found out several years down the line. I just hope that any funding needed to research this kind of stuff is pretty much limitless, my career in an engineer Research and Development management position really has shown how insufficient funding really can bite you further down the line....
Apr 23, 2024
349
277
935
High altitude ice crystals ( cirrus stratos I think) do the same thing, also If elon musk gets his way with the starlink program there will be enough high altitude (low orbit) telecomms satellites ( and bits) in orbit to dim the sun :ROFLMAO: :ROFLMAO: :)
5,009
The other concern is that the UK is falling over itself to promote the idea and it seems without any consultation! Surely as inhabitants of the earth we should be given the opportunity to voice our concerns? If it goes wrong we are the ones that will suffer the consequences.
8,669
Jet fuel contains sulphur so why not just keep on flying as the carbon dioxide emitted might be countered by the effects of the jets emissions. Nett result: nil warming. Bingo.
  • Wow
5,009
That is too simple for them to understand!
4,161
I agree Stratospheric Aerosol Injection or SAI is a thought provoking concept, and one that tis not new. I recall a similar scheme was exposed where the idea of SAI was part of a military weapon to deprive some countries or regions of sun light to prevent crops from growing.
We have enough trouble predicting weather conditions due to chaotic activities or multi layer air flows in the atmosphere, so there would inevitably be similar uncertainties about how SAI would spread around the globe.
5,009
Agree, but the UK is pushing ahead with it according to reports and it may be finalised later this month? :censored:
8,669
The UK trials are quite limited in their scope and really are only pilot trails. There are also others around the world so I'd expect the various trial bodies to come together at some stage to discuss results and assess the scope for further work, or not as the case may be.
5,051
I bet there are some serious downsides.
There could be unintended consequences to using such an untested artificial change to nature. Maybe the ecological impacts such as ocean acidification will have a negative effect on ocean life.
What happens if these particles fall to earth or and we breathe them in? Back to the Woodbines.
5,009
However, why do something they could possibly have horrific consequences for the population as basically they are using us as guinea pigs. The effects on the environment could be even worse!
8,669
It would seem that small scale “ private”” trials have been conducted already by a UK researcher. The article below from MIT isn’t too complimentary about the way the trial was conducted. However in overall scale orders of magnitude less than even a small scale volcanic eruption.
Jul 23, 2021
1,022
968
5,435
I am not for or against the small scale trials here, though I am skeptical of the possible design goal and impact in a full scale deployment (the sun produces a vast amount of energy over a huge area, so to reduce it needs a huge input).
Of course one could ask the question "Why continue doing something that has proven horrific consequences for the population, and evidence of the consequences is both measurable and tangible?"
Maybe better to tackle the issue at source rather than apply a band aid afterwards...
4,161
Its very unlikely to be converted to a full scale attempt for at least another 4 years 6 months on, as the country most likely to initiate such a scheme at scale presently doesn't have a government that believe there is any crisis with the environment, and hopefully when someone with realistic views of the worlds situation is elected as president, the trials of SAI will have hove shown how unpredictable the results will be.
5,009
In the meantime, taxpayers money is probably being used to fund this fantasy. I can see the UK going ahead and then being sued by other countries for their weather being affected and our obliging government paying. Obviously governments have never heard of ill winds etc!
Jul 23, 2021
1,022
968
5,435
Taxpayers money is continuously being used to fund research. The purpose of research is to understand things that were previously not understood, with the aim of bettering our environment. Is this tax payers money in this case ? The MIT article suggests the individual is independent of a university.
5,009
The UK government is not getting it for free and subsequent governments may have to deal with any fall out?
8,669
Do you seriously think that small scale UK trials are going to have a global effect? What about the times when multi megaton devices were exploded around the globe? Or when areas of Britain were sprayed with wintergreen to simulate a biological weapon attack? Mount Pinatuba emitted thousands of tons of SO2 which led to a short term atmospheric cooling of 1 deg C. So there’s a long way to go on this one. Better perhaps to reduce CO2 and methane emissions as the primary aim.
Reactions: ProfJohnL
5,009
I refer to #18 by DD.
5,051
Don’t forget we already have “Volcanic Winters”. More than enough evidence to explain what happens and it doesn’t cost a massive fortune.
You will all know there is a very weird proposal to reduce energy costs in the North and increase them in the South. 🤬
