Hi to you all out there. I have just had my twin axle caravan repaired,yes the dreaded cracked aluminium skin and dropped floor at both front corners along with all of the associated 'piggy back' issues that often blight a particular caravan manufacturers products albeit mainly confined to certain model variants since circa 2001.
My caravan was repaired by the team from West Riding Leisure at Lockwood Scar,Huddersfield.
The result is just as I was expecting/anticipating having seen their work and having had them very strongly recommended by a member from 'The Other Forum'.
The 'D' moulds ( the ones that have vinyl glued on) that cover the joints of the ceiling boards and very soon start shedding the vinyl like snakes shed their skins have all been replaced and really do look the business.
The removal and replacement of the internal board and all fitments in order that the aluminium skin repair and associated strengthening could carried out is virtually undetectable but for a very slight difference in the graining of the vinyl skin/print.
The dropped front corners and floor has been repositioned and bonded into place and all new fixings inserted.
The floor was never previously bonded and simply relied on screws going into the edge of the floor for any 'offering' of a fixing.
There was an issue with damp at the junction of the NS awning rail and the cover strip across the front of the caravan front cap. That has all been rectified and affected timbers were replaced.
The integrity of the front locker at both sides is now vastly improved as opposed to the original build that failed along with the dropping of the two front corners of the floor.
All-in-all the caravan is now no longer worth only the scrap value (£900.00) and is now again a perfectly usable and or saleable twin axle touring caravan.
Thank you West Riding Leisure.
