Add a leisure battery
Sep 30, 2020
Hi folks thinking of adding a leisure battery to existing one .i have a 61 plate swift escape on Fiat Ducato 130 multi jet .
Can anyone see any probs ie will split charger cope etc
Appreciate any help/advise
Oct 8, 2006
2,040
719
Seek advice from a Fiat dealer or a good towbar fitter. If your Ducato has CanBus then you may need to use the manufacturer harness and have the ECU updated so that the latter knows when you are towing. Most certainly using a split charge relay on modern vehicles is not a good idea.
4,332
There shouldn't be a problem, unless your vehicle has a smart alternator.
Do be aware that the leisure battery needs to be in a separate enclosure and vented to the outside.
